Home » Sponsored » Pi Speakers » Theatre 4 Port Size
Theatre 4 Port Size [message #33983] Mon, 01 October 2001 07:21 Go to next message
Hi Wayne, is 4" PVC okay for the port?
If I can lay hands on a digital camera can I qualify for Pi decals?
Re: Theatre 4 Port Size [message #33984 is a reply to message #33983] Mon, 01 October 2001 13:00 Go to previous messageGo to next message
PVC pipe will work just fine for your port. Send me your mailing address and I'd be happy to send you a couple Pi logo decals.
Re: Theatre 4 Port Size [message #33989 is a reply to message #33984] Tue, 02 October 2001 06:43 Go to previous messageGo to next message
Crazy Dave is currently offline  Crazy Dave
Hi Wayne,
Can I get a couple logos too?
Thanks in advance!
Dave
Re: Theatre 4 Port Size [message #33991 is a reply to message #33989] Tue, 02 October 2001 07:46 Go to previous messageGo to next message
Sure, no problem. Send me your address and I'll send out the Pi logos.
Re: Theatre 4 Port Size [message #33999 is a reply to message #33991] Wed, 03 October 2001 06:42 Go to previous messageGo to next message
Hi Wayne,
If you were designing a speaker for a theater or an auditorium, would you then increase the box volume? I think this would give you more lows and a sharper roll off, giving up some control. I guess you could also equalize instead (like KEF and Bose did).
Dave
PiAlign and bass reflex tuning [message #34000 is a reply to message #33999] Wed, 03 October 2001 07:44 Go to previous messageGo to next message
In the case of most high efficiency woofers, PiAlign tends to make cabinets that are relatively small and slightly overdamped. Overdamped alignments are very forgiving of parameter shifts and room conditions. The relatively small box is also convenient, although larger boxes potentially offer greater extension.
Re: PiAlign and bass reflex tuning [message #34003 is a reply to message #34000] Wed, 03 October 2001 10:29 Go to previous messageGo to next message
Hi Wayne,
What you say certainly does make sense. I think I will re-read your Pi-align paper.
Does your Pi-alignment give you the double hump impedance curve that is normally associated with ported systems?
Dave
Re: PiAlign and bass reflex tuning [message #34004 is a reply to message #34003] Wed, 03 October 2001 10:40 Go to previous message
Yes, there are two impedance peaks.
Previous Topic: Gamma Pi-align PA box and some other pics
Next Topic: question from a novice
Current Time: Sat Nov 14 13:06:43 CST 2026
