Home » Sponsored » Pi Speakers » Pi Aligned Afterburner & Port Calculation
Pi Aligned Afterburner & Port Calculation [message #33942] Thu, 27 September 2001 06:43 Go to next message
Observator is currently offline  Observator
Hello,
I'm just started to build a Pi-aligned version of Thorsten's Afterburner. I haven't yet the RS tweeter, but I will try the piezo - maybe KSN1038 ? May this be a good match for the 99dB of Beta 12LT ? I used the values given by PiAlign soft, the same as Wayne gave in this post.
I tried to re-do the calculation for the port dimensions (I like verify the things before cutting :). Unfortunately it doesn't work as I supposed. For 2.5" diameter port that's 2.75" long I've got 0.1Hz instead of Wayne's 33Hz . More details, see link. What's wrong ?
Thanks in advance,
O'Tor
Re: Pi Aligned Afterburner & Port Calculation [message #33949 is a reply to message #33942] Thu, 27 September 2001 11:26 Go to previous messageGo to next message
You used 2.4 as as cabinet volume but you should have used 2.4 x 1728 to convert it to cubic inches. You must use the same terms throughout - If inches in one place then inches must be used everywhere. You can use feet if you wish, but then the port dimensions must be in feet for "Lc" and sq. feet for "Ap".
Re: Pi Aligned Afterburner & Port Calculation [message #33950 is a reply to message #33942] Thu, 27 September 2001 12:57 Go to previous messageGo to next message
AudioLapDance is currently offline  AudioLapDance
Hey Observator,
See my post "Crossovers for Delta15 @ 700 Hz, Beta12LT @ 15kHz? " below. There are others as well; just take a look.
I tried Wayne's crossover and the KSN1038 but the piezo didn't seem loud enough to me. I was thinking of trying the more sensitive KSN1177--it's basically two piezos side by side!
You might want to redo the PiAlign calculations with the "new" Beta12LT specs off the eminence site. The data file in the PiAlign program uses the "old" specs.
Good luck,
Jeff
Re: Pi Aligned Afterburner & Port Calculation [message #33970 is a reply to message #33949] Sat, 29 September 2001 13:02 Go to previous messageGo to next message
Thank you for the response.
...but my problem persist....
I suppose I am wrong but I cannot find where :-(
Question is : what is eqation Fre = 1/2pi * sqrt(Ap/VeLc)
calculating?
Using your values and formules from Pi white paper,
Ve = 2.45 cu ft = 4242 cu in then
Dp = 2.5" => Ap = 4.9 sq in
Lp = 2.75" => Lc = 4.872 in
Fre = 1/6.28 * sqrt (4.9/(4242*4.872) )= 0.00245 Hz :-(((
Thanks in advance,
O'Tor
Re: Pi Aligned Afterburner & Port Calculation [message #33971 is a reply to message #33950] Sat, 29 September 2001 13:36 Go to previous messageGo to next message
Hi there,
thanks for the type...
Thanks for your opinion!
Wayne allready used this new values (Qts/Fs = 1.51/45).
How is your Beta 12LT performing ?
O'Tor
Re: Pi Aligned Afterburner & Port Calculation [message #33976 is a reply to message #33970] Sat, 29 September 2001 16:07 Go to previous messageGo to next message
Look closely at the Pi Alignment Theory whitepaper. The formula you've shown above is on page 5. In this formula, the "l" term is a lower-case "L" and not the number "1". This value is used to show the speed of sound in inches per second, or 13548. So multiply your results by 13548 and you'll arrive at the proper and expected answer.
Thanks a lot ! (nt) [message #33978 is a reply to message #33976] Sun, 30 September 2001 03:39 Go to previous message
nt
Previous Topic: Which drivers are suitable for Pi alignment?
Next Topic: Pair of JBL 2426H drivers FS.
Current Time: Sat Nov 14 13:06:59 CST 2026
