Home » Sponsored » Pi Speakers » theil-small params for Fostex FE-103 (RS 40-1197)
theil-small params for Fostex FE-103 (RS 40-1197) [message #33907] Tue, 25 September 2001 07:51 Go to next message
Hi Folks,
I'm trying to find the T/S parameters for those little 4" full
range drivers from Radio Shack. I have one in a TQWP box that
works pretty well, but I'm thinking about putting two plus a piezo
tweeter in a Pi-aligned box for use as rear channel HT speakers.
They'll be good to about 80-100Hz. What I don't have is Vas
or resonant freq.
Thx, Chris
Re: theil-small params for Fostex FE-103 (RS 40-1197) [message #33913 is a reply to message #33907] Tue, 25 September 2001 16:32 Go to previous messageGo to next message
Here's what I have for the Fostex FE-103E. Not sure if it's the same as the Radio Shack 40-1197 or not.
Vas = 420 c.i.
Qts = 0.35
Fr = 80Hz
Sensitivity = 89dB/2.83v/M
Max power = 15W
Xmax = 0.01"
Re: theil-small params for Fostex FE-103 (RS 40-1197) [message #33921 is a reply to message #33913] Wed, 26 September 2001 12:03 Go to previous messageGo to next message
MikeSt is currently offline  MikeSt
I found this at www.radioshack.com It's not the complete T/S params, but it's a start. I'd do a search on the Full Range Driver Forum http://f18.parsimony.net/forum31999/ to see if the info is there. If not, post a message. Many folks on that forum have worked with the RS 40-1197.
MikeS
GENERAL
Nominal Impedance:.........................8 Ohm +/- 15% at 1.6 V & 400 Hz
Resonance Frequency:..............................80 Hz +/- 15 Hz at 1.6 V
Sound Pressure Level:................................90 dB/W (1m) +/- 2 dB
Power Handling Capacity:...............................................3 W
Music Power:..........................................................15 W
Weight:...................................................590 g (20.85 oz)
MAGNET
Dimensions:................................................80 x 40 x 10 mm
Weight:..................................................188.5 g (6.65 oz)
VOICE COIL
Nominal Diameter:......................................20.32 mm (0.8 inch)
Bobbin Material:.....................................................Paper
Wire Size:.........................................................0.12 mm
DC Resistance:.....................................................7.6 Ohm
Turns/Layers:............................................76 Turns/2 Layers
Winding Length:.....................................................5.6 mm
Re: theil-small params for Fostex FE-103 (RS 40-1197) [message #33960 is a reply to message #33921] Fri, 28 September 2001 07:41 Go to previous message
Thanks Wayne and Mike, that is just what I needed.
Chris
Previous Topic: #1- Squaring up Sheet stock on the table saw
Next Topic: Port length on multiple ports
Current Time: Sat Nov 14 13:06:46 CST 2026
