Home » Sponsored » Pi Speakers » port dimensions - pro pi7
port dimensions - pro pi7 [message #33863] Mon, 17 September 2001 07:40 Go to next message
jazzbo is currently offline  jazzbo
Hi Wayne-
Sorry to bother you with another question, but better safe than sorry when it comes contruction. If you don't mind could you please clarify the 15 1/8" dimensionon the pro pi7 plans. I am thinking that it is the distantce from the outside of the cabinet to either the inside or outside of the port (the piece of plwd that defines the length of the port). If this is the case, I was trying to determine how this configuration would result in a port length of 12" as determined in the pialign program. I noticed there is an adjustment of lenght due to area, but I could not find a formula for calculating this adjustment. Also, for a port that "turns corners" like the one for the pi7, is the adjusted port length then measured along the centerline of travel through the port?
Thanks again for your patient answers.
Re: port dimensions - pro pi7 [message #33870 is a reply to message #33863] Mon, 17 September 2001 22:00 Go to previous messageGo to next message
The port is 15 1/8" long and shares a wall with the cabinet. It sort of looks like a periscope. It can't be described very well with the Helmholtz formula because of its unusual shape. But I've tested it to make sure it's right.
Re: port dimensions - pro pi7 [message #33871 is a reply to message #33870] Tue, 18 September 2001 07:33 Go to previous messageGo to next message
Thanks Wayne-
I can see that the physics of speaker design can become quite complex!
Just a couple of short follow-ups:
Is the 15 1/8" dimension (shown on the pro pi7 plan), the inside measurement of the port, or from the outside of the cabinet to the inside of the port?
If one wanted to stay with a straight port, could it simple exit the side? I know this may not look the best, but I was wondering if it would be worth considering.
Thanks Wayne
Re: port dimensions - pro pi7 [message #33872 is a reply to message #33871] Tue, 18 September 2001 16:02 Go to previous message
15 1/8" is an inside dimension. The port shape can be anything, but the Helmholtz formula is a simplification that only describes straight ports. That doesn't mean a curved or bent port is a problem, it's just that you want to measure impedance of the finished cabinet to confirm the resonant frequency is right.
Previous Topic: Where to source port for Theatre 4's?
Next Topic: pi horns theory
Current Time: Sat Nov 14 13:07:05 CST 2026
