Home » Sponsored » Pi Speakers » Where to buy JBL2426 diaphrams?
Where to buy JBL2426 diaphrams? [message #33445] Fri, 22 June 2001 09:08 Go to next message
James W. Johnson is currently offline  James W. Johnson
I am preparing to build the Pi 4 pro series speakers and I would like to have a few replacement diaphrams on hand in case I blow one, where can I buy them for the JBL 2426H ?
Re: Where to buy JBL 2426 diaphrams? [message #33447 is a reply to message #33445] Fri, 22 June 2001 19:12 Go to previous messageGo to next message
You can get them from Speakerworks at (918) 664-6299. Ask for David Miller.
Re: Where to buy JBL 2426 diaphrams? [message #33448 is a reply to message #33447] Fri, 22 June 2001 20:53 Go to previous messageGo to next message
I doubt I'll need them... but then again... I push my speakers pretty hard.
Re: Where to buy JBL 2426 diaphrams? [message #33450 is a reply to message #33448] Sat, 23 June 2001 01:28 Go to previous message
The 2426 on the horn will produce 100dB with 1/10th watt input, measured 1 meter away. It produces 130dB at maximum output. So if you blow one of these while listening in your home, you probably should have your hearing checked. Seriously.
Previous Topic: Any thoughts about the Peavey 22XT?
Next Topic: Biamping-xovers-12, 18, or 24db/oct?
Current Time: Sat Nov 14 13:06:43 CST 2026
