Home » Sponsored » Pi Speakers » Eminence solves the "mystery parameters" issue - Second letter
Eminence solves the "mystery parameters" issue - Second letter [message #33092] Tue, 27 March 2001 09:08
Hi Wayne,
I completely understand your position and we will keep you on our mailing
list. Just like you, I hate to see parameters change also! Talk about some
work! It gets really crazy and the potential for mistakes is huge.
In fact, another reason for the last revision was that we seemed to have
gotten different data in different places ie. catalog, web site, Eminence
Designer. I felt that it was prudent we take a close look at all the
published information and get it exactly right in all locations.
The fact is, I do not anticipate another change again. Should a component
change that affects the performance of the speaker, we will simply source
another component so that we can maintain the performance of the speaker.
The bottom line is, I will inform you of any future changes, but can fairly
well assure you none will occur.
Thanks again for your patience and understanding on this matter.
We appreciate the fact that you use Eminence and support our company. We
want to support you as well.
With kind regards,
Chris Rose
Eminence
Previous Topic: Car Subwoofer Encloser
Next Topic: Hi...some questions...
Current Time: Sat Nov 14 13:05:17 CST 2026
