Home » Audio » Group Build » Nice to see this group idea wasn't in "Vane".
Nice to see this group idea wasn't in "Vane". [message #31988] Mon, 18 September 2006 14:41 Go to next message
Now this is what it is all about. I see group buys on other sites and group builds; but this should be a real winner judging by the work and enthusiasm so far.
I am very excited about this and can't wait like a kid at Christmas.
Now I need a 12" driver in a 4 cu ft bass bin to complement the horn.
Re: Nice to see this group idea wasn't in "Vane". [message #31989 is a reply to message #31988] Mon, 18 September 2006 15:14 Go to previous messageGo to next message
Please send the plans when you're ready; I'll post the blueprints in the Projects folder. Ownership of plans is retained by the authors, but license is granted for anyone to use them. Keeps things above board.
Re: Nice to see this group idea wasn't in "Vane". [message #31990 is a reply to message #31989] Mon, 18 September 2006 17:53 Go to previous messageGo to next message
This project really interests me, but what would a pair of these type of horns cost in general to make including a suitable driver?
Re: Nice to see this group idea wasn't in "Vane". [message #31993 is a reply to message #31990] Mon, 18 September 2006 20:38 Go to previous messageGo to next message
Hi Shane,
I figure it'll have anywhere from 8 to 10 square feet of material to complete the horn. If you're using baltic birch ply, that would be less than 1/2 sheet and run you less than $20. If using MDF, figure about $10 of material.
If you choose to buy a set of vane, from whomever it may be, add that to the cost.
The horns should be usable with most 1" exit compression driver similar to the Eminence PDS2002 in Pi speakers. That was the big reason why I was pushing for this version of the horn because lots of guys already run 1" compressions.
gar.
Thanks Garman. [message #31994 is a reply to message #31993] Mon, 18 September 2006 21:34 Go to previous messageGo to next message
Pretty reasonable really. Seems I should go ahead and get the vanes while they're being made.
Re: Thanks Garman. [message #31995 is a reply to message #31994] Tue, 19 September 2006 08:08 Go to previous messageGo to next message
By the way Shane, do you still have your 2-Pi towers? If so, these horns could work well with those speakers.
Place the horns on top of the cabinet. Cross the woofer to the horns at 1600Hz. Bring the tweeter in above 10KHz with a single cap.
Re: Thanks Garman. [message #31996 is a reply to message #31995] Tue, 19 September 2006 09:37 Go to previous message
I was wanting to try implementing them with the Two Towers. Thanks for the suggestion!
Previous Topic: Re: Vanes
Next Topic: Back to the Horn
Current Time: Tue Oct 13 09:16:18 CDT 2026
