Home » Audio » Group Build » Guinever underside
Guinever underside [message #30756] Mon, 28 February 2005 18:28 Go to next message
More cakepan chasie work. Cheep, easy to work and you get a cherry cobbler recipe to boot...John
I see now.... [message #30762 is a reply to message #30756] Mon, 28 February 2005 19:55 Go to previous messageGo to next message
You aren't using the second 5687. I suspect you're going to try 12B4 sooner or later aren't you? Good move IMO, but I would not throw a 5687 out ov bed either.
The regulated linestage you heard in MD now has an RK34 amplifier valve. Two anode caps, mu of 13, and an 816-ish bottle. It looks quite cool.
regards,
Douglas
Re: I see now.... [message #30767 is a reply to message #30762] Mon, 28 February 2005 22:01 Go to previous messageGo to next message
Yes I set out to go with 12b4's as I always end up with more gain than I need. But you all caught me at a week moment with the transformer. I was just finishing my trials with the $12 Allied. when you were ploting this one, so I bought one, then well I have some 87's in the bin. what the hell group build sounds like fun.
The rectifer is a 6by5 and i have not listened to it yet. The wallwart I got at the thrift shop is dead...John
Where's R1? [message #30768 is a reply to message #30756] Mon, 28 February 2005 22:47 Go to previous messageGo to next message
I don't see the resistor R1 (1k) off the potentiometer. Am I just missing it or is not there?.....Colin
"Cheap, easy to work and you get a cherry cobbler recipe to boot" [message #30770 is a reply to message #30756] Tue, 01 March 2005 01:24 Go to previous messageGo to next message
Re: Where's R1? [message #30772 is a reply to message #30768] Tue, 01 March 2005 08:28 Go to previous message
R1 is a grid stopper, on reflection I will probably add it.
They are not strictly necessary but are good isurance against oscillation
I left out R5, I think the amp will be sufficient load...John
Previous Topic: LEDs light - can I assume CCS is wires properly?
Next Topic: Grid stopper resistor placement
Current Time: Wed Nov 25 00:12:14 CST 2026
