Home » Audio » Group Build » Choke order
Choke order [message #30387] Fri, 04 February 2005 12:41 Go to next message
Trying to finish up ordering and upon looking for the choke value I see the BOM has 30hy/40ma but then in a more recent post I see 20hy/100ma. So; can anyone enlighten me? Thanks J.R.
Re: Choke order [message #30390 is a reply to message #30387] Fri, 04 February 2005 13:28 Go to previous messageGo to next message
T suggested going with the 20Hy/100mA over the 30Hy/40mA because of the current draw. I was planning on using Hammond's 193C.
Below is the link I got this from. Look down until you see my post entitled "Hammond choke." Please follow thread and help me understand if I'm about to order the wrong item......Colin
Re: Choke order [message #30394 is a reply to message #30390] Fri, 04 February 2005 15:04 Go to previous messageGo to next message
I don't see the link? I am ordering from Heyboeur I think, are you still doing the Hammond? Also I oredered 4 of the 100uf oilers and 4 7.5 uf oilers; does that sound right?
Choking.... [message #30411 is a reply to message #30394] Sat, 05 February 2005 20:17 Go to previous messageGo to next message
Hey-Hey!!!,
The 20 Hy/100 mA Hammond 193C is a fine piece. We are about double critical current with 250 volts input. This also offers the additional current handling to change taps onthe PT and go fith a shunt regulated VR-tube power supply later.
The Hammond is a litle less than half the price of the 8039 Heyboer choke at about $30 instead of $70 or so.
It looks like you guys are in fine shape.
regards,
Douglas
Re: Choking.... [message #30421 is a reply to message #30411] Sun, 06 February 2005 09:34 Go to previous messageGo to next message
8039; thats the part no. I needed.
Re: Choking.... [message #30423 is a reply to message #30421] Sun, 06 February 2005 11:13 Go to previous message
Oh, the 'big one'. Nice choice. I am listening to mine right now. A super L in the L-C filter is a wonderful thing.
Tell them what sort of endbells yo want. You can get them like the power Iron of a St-70 Dynaco, which requires a bigger and more troublesome hole in the chassis, or vertical.
Critical curent for that one with even 500volts to the rectifiers is about 10 mA. I am taking 4x that much and the PS is showing .2 V of ripply. Just as PSUDii predicted. Nice to have a good Sim, that's for sure...
regards,
Douglas
Previous Topic: Gueinevere
Next Topic: Juvenile request
Current Time: Fri Oct 23 05:51:42 CDT 2026
