Home » Audio » Group Build » C1, 4.7uF cap
C1, 4.7uF cap [message #30221] Sat, 22 January 2005 18:49 Go to next message
Is there a minimum voltage rating? Can someone please make a little friendly suggestion as to what might possibly sound best?
Re: C1, 4.7uF cap [message #30222 is a reply to message #30221] Sat, 22 January 2005 19:46 Go to previous messageGo to next message
No problem! I like the ASC motor run. 440VAC/7.5 uF at ~$8 each from Allied Electronics. Slight preference to the lower voltage versions, but at a slight size penalty. It is what I have been running since Rev. 2 and I have tried a bunch of things. The ASC keep going back in.
regards,
Douglas
Re: C1, 4.7uF cap [message #30224 is a reply to message #30222] Sat, 22 January 2005 19:58 Go to previous messageGo to next message
I have good luck with Allied. Julia is very helpfull. That cap is the output coupling cap; is that correct? If so would it be possible you might walk us through the Ohm's law math required to find that value? I understand if it is too much but I am attempting to access the Radiotron theory and struggling due to lack of math skills. I also happen to have the NEETS program I ordered a while ago. Anything pertinent in there. I see you have used it twice now. Thanks Douglas. We are very hyped about the 807 amp project to pair with the pre.
I have traded my EAR el 859 in order to do PP and this is right up the alley.
C1, 7.5 uF/440VAC [message #30229 is a reply to message #30224] Sat, 22 January 2005 20:21 Go to previous messageGo to next message
it is indeed the output coupling cap. Since the impedance of a cap is 1/j-omega-C, we want the cap as large as is sonicaly reasonable. Forget about j and root negative 1. It is the real part of this we will look at.
At 20 cps, omega is 2*Pi*20 radians per second and C is 7.5 * 10^-6.
this yeilds 1061.03295 Ohms. At 40 cps, it is half that, and at 80 cps, half of that. This is close enough to the 10:1 ratio of input impedance to output impedance which keeps us from rolling off too early, even with a 10kOhm SS amp. For a 100kOhm Valve amp and several tens of pF of cabling capacitance, we're still good.
regards,
Douglas
Re: C1, 7.5 uF/440VAC [message #30238 is a reply to message #30229] Sun, 23 January 2005 06:59 Go to previous messageGo to next message
Excellent; thanks again!
How's this cap? [message #30268 is a reply to message #30229] Mon, 24 January 2005 14:24 Go to previous messageGo to next message
It's rated at 370V, not 440V? Price is right....Colin
That is a *FINE* cap... [message #30271 is a reply to message #30268] Mon, 24 January 2005 15:29 Go to previous message
rock on me old Mate, that'll do just fine.
regards,
Douglas
Previous Topic: T, confirm correct transformer spec from Heyboer
Next Topic: trade DN2340 For tube sockets?
Current Time: Thu Nov 12 11:17:11 CST 2026
