Home » Audio » Craftsmen » soapstone
soapstone [message #29724] Thu, 26 January 2006 09:34 Go to next message
Has anyone every worked with soapstone. From everything I've read, it can be worked the same as wood, more or less. One can route the edge with a router and carbide bits, and cut holes with a standard hole saw. Just wondering before I screw up a slab......Colin
Re: soapstone [message #29725 is a reply to message #29724] Thu, 26 January 2006 14:11 Go to previous message
I suggest that you screw up a small piece of scrap before screwing up the slab.
(not helpful at all, I know)
Previous Topic: Finish for Purpleheart
Next Topic: Upholstery
Current Time: Fri Oct 23 00:31:35 CDT 2026
