Home » Audio » Craftsmen » Holes in metal w/o chassis punch. HELP!!!
Holes in metal w/o chassis punch. HELP!!! [message #29382] Wed, 26 January 2005 20:07 Go to next message
I need to put a couple of 0.75" holes in a piece of copper sheeting. Yeah, I know a chassis punch is the way to go, but I don't have one. Any ideas?......Colin
Re: Depends on thickness [message #29383 is a reply to message #29382] Thu, 27 January 2005 03:11 Go to previous messageGo to next message
If it's very thin you'll need to sandwich it between 2 pieces of plywood and clamp. Thicker sheet means cooling as you drill, a squirt of 3 in one oil. Just use one of those 'bi-metal' hole saws you buy at Lowes/Home Depot. About $10. Be sure and clamp the workpiece to the bench or drill press table. If you don't, the workpiece can easily get away from you and spin.
That's bad!
Better yet, while you're buying the hole saw, see how much a Greenlee punch is over in the electrical dept.
Re: Holes in metal w/o chassis punch. HELP!!! [message #29384 is a reply to message #29382] Thu, 27 January 2005 07:29 Go to previous messageGo to next message
Hole saws have worked pretty well for me. I use it free-hand with a hand drill. Just go slow and use a bit of lubricant like Bill said. I always make sure there's a nice thick piece of MDF clamped tightly under the piece of metal to make sure the bits don't wander.
Gar.
Another thing: WEAR EYE PROTECTION! (nt) [message #29385 is a reply to message #29384] Thu, 27 January 2005 07:57 Go to previous messageGo to next message
ny
Re: Another thing: WEAR EYE PROTECTION! (nt) [message #29386 is a reply to message #29385] Thu, 27 January 2005 09:02 Go to previous messageGo to next message
Since second semester organic I always do. One experiment made a true believer out of me. It went BOOM in my face....Colin
Hole saw worked like a champ. Thanks (nt) [message #29387 is a reply to message #29384] Fri, 28 January 2005 23:16 Go to previous message
Previous Topic: Magic Eraser cleans metal, too
Next Topic: Plywood Edge Protection
Current Time: Sun Oct 04 13:13:20 CDT 2026
