Home » Audio » Craftsmen » DEFT
DEFT [message #29321] Tue, 14 December 2004 07:03 Go to next message
Doc Jr 8156 is currently offline  Doc Jr 8156
Hello,
Just wondering if DEFT lacquer can be applied to stained finishes. For those who had experience with DEFT, typically how many coats needed to provide a great finish? Thanks. Godspeed.
Re: DEFT [message #29323 is a reply to message #29321] Tue, 14 December 2004 19:14 Go to previous messageGo to next message
You can apply Deft over a stained finish. If your brushing the finish you can get a good film buildup in 4 or 5 coats. If your spraying the Deft from a Deft can, expect to shoot 8-10 coats.
In short. If your looking for a breushing lacquer Deft is pretty good and you can have a nice build with a few coats. The Deft spray cans are better suited for touch up unless your happy with a thing film finish.
Bill
Re: DEFT [message #29324 is a reply to message #29323] Tue, 14 December 2004 22:52 Go to previous message
Bill,
Thank you very much. I will brush the DEFT to finish my Bob Brines designed TQWTL using the Fostex 200A. Godspeed.
Previous Topic: What do you call that thingy that ...
Next Topic: Isn't anyone building anything???
Current Time: Thu Oct 29 16:27:24 CDT 2026
