Home » Audio » Home Theater » Can Scart switchers affect sound?
Can Scart switchers affect sound? [message #28597] Sat, 09 September 2006 05:33 Go to next message
eatli is currently offline  eatli
I have a lot of devices plugged into my TV, so bought a Mad Catz switcher for the consoles.
Since starting to use it, I've found that the Gamecube, 360 and Xbox all seem OK, as does the DVD player, but the PS2 has developed a fuzzy picture and a terrible humming noise under the sound.
I've tried a spare cable and the problem persists. I'd test it without the switcher but that would mean a massive rearranging of furniture to get at the back of the TV and I really can't face that
Is it likely the problem is the swithcer, bearing in mind that everything else plugged into it is fine?
Re: Can Scart switchers affect sound? [message #28598 is a reply to message #28597] Fri, 15 September 2006 11:12 Go to previous message
The problem is probably caused by interference from a digital signal. It might be a bad ground, or it might be poor shielding. You may want to isolate the PS2.
Previous Topic: Philips outlet
Next Topic: Outdoor HT
Current Time: Sat Oct 31 07:27:32 CDT 2026
