Home » Audio » Home Theater » Tubed HT system
Tubed HT system [message #28491] Sat, 26 February 2005 19:16 Go to next message
tybee is currently offline  tybee
I currently have an all tubed Eastern Electric component system with Galante Rhapsody speakeers(Radian Compression Driver) in a small,dedicated music room. The Galantes are 96Db efficient so my EE 8 watt tube amp has plenty of headroom with the EE Mini Max pre-amp for a smaller room. I have a small Acoustic Energy HT Processor which could be used to drive an all tubed 4.1 HT system. (I would run the front Galantes through my EE Pre-amp) Since the rear speakers are not as critical in an HT application, I have been searching for suitable (smaller rear speakers) to use in this system. I would prefer to use a small tubed amp or maybe digital amp to drive the rears, so a efficent speaker would be needed. The speaker probably would need to be front ported for placement on the rear wall. (Oh yes, I would be using a wall mounted LCD display.
Any recommendations?
Re: Tubed HT system [message #28492 is a reply to message #28491] Sun, 27 February 2005 12:10 Go to previous message
Look at Pi one
Previous Topic: Cable TV hum
Next Topic: speaker cable length for HT
Current Time: Sat Oct 31 07:28:01 CDT 2026
