Home » Audio » Pro Sound » linear amps???
linear amps??? [message #27107] Thu, 14 July 2005 08:07 Go to next message
joseph is currently offline  joseph
if an amp is "Linear" what does that mean, i guess its some thing to do with the way it is wired, but what does it do to the sound, and what does it say about quality of the amp. also - what are tube amps? thanks
Re: linear amps??? [message #27110 is a reply to message #27107] Thu, 14 July 2005 11:58 Go to previous message
Linear just means, "like a line." If something is linear, it is straight. It is often used to describe something that is free of peaks and valleys, consistent in its performance. This term is used in all aspects of electronics, and is generally a good trait.
The term "linear amplifier" is also sometimes used to describe a wide band amp, one that isn't optimized or tuned to a particular frequency band but one that can operate from DC or very low frequency up into the high RF range.
Tube amps are those that use vacuum tubes as their active elements instead of transistors or FETs.
Previous Topic: Speaker replacement and problem with Laney VC30
Next Topic: peavy classic 50 problem
Current Time: Wed Oct 21 18:13:06 CDT 2026
