Home » Audio » Pro Sound » Marshall DSL50 v DSL100
Marshall DSL50 v DSL100 [message #27057] Mon, 23 May 2005 13:43 Go to next message
al is currently offline  al
Can anyone give me the benefit of their experience. At present I am using a Marshall 100DFX with a 1960 4x12 cab. I wish now to purchase a valve amp. I am torn as whether to buy the Marshall DSL 50 or the Marshall DSL 100. I use the Boss GT6 processor which is great. The band I am with generally play medium sized venues and the cabs are generally miked through the house PA. I am tempted to go for the bigger one but I have heard that the 50watt model can give a better sound, I am worried that the smaller amp will give me problems in the future as the band is on the up and will soon be playing bigger venues, or should I play safe and go for the 100watt model. Will the fact that I use the GT6 make any difference to my choice. Thanks in anticipation
Re: Marshall DSL50 v DSL100 [message #27060 is a reply to message #27057] Thu, 26 May 2005 10:10 Go to previous messageGo to next message
I feel bad about raining on everyone's parade, but here's my $.02.
From a formula point of view, the 100W amp is only 3db louder which
is barely noticable. That's when running flat out. If you are
mic'ing anyway, that really doesn't matter. When you throw a
processor in front of the thing, I'm convinced you lose a lot of
the raw dynamics which lessens the differences again. When you are
playing with a band, you can't hear most of that anyway. The one
thing to consider is that some amps sound best when really cranked.
Its easier to live with a cranked 50W'er than a cranked 100W'er.
Think stage volume and/or smaller venues. You really need to
play both side by side and see what's really different.
Chris
Re: Marshall DSL50 v DSL100 [message #27061 is a reply to message #27060] Sun, 29 May 2005 17:26 Go to previous message
Thanks Chris some good points to consider, do you have any thoughts on the Marshall DSL, in comparison to other makes eg. Crate Blue Voodoo.
Cheers
Al
Previous Topic: Channel jumping inputs fender to Matchless
Next Topic: Plans for trap box 15 and horn
Current Time: Wed Oct 21 17:03:41 CDT 2026
