Home » Audio » Pro Sound » fender Blonde surf showman tremolo
fender Blonde surf showman tremolo [message #27026] Sat, 30 April 2005 00:56
walters is currently offline  walters
1.) Why does the fender Blonde showman tremolo
based for surf tremolo have a certain
compression and decay for the tremolo?
2.) How is it set to have the tremolo compression?
Not using a compessor this is internal
in the fender showman amps done in the
design
3.) How to set the Tremolo Decay?
a.) What network makes the tremolo
Decay? long or short?
b.) what components can i change
to play with the tremolo Decay?
4.) Does the tremolo lamp have to do with
the sound of it ?
Previous Topic: Traynor YCV20 EQ Problem
Next Topic: SWR California Blonde distortion.
Current Time: Wed Oct 21 18:04:00 CDT 2026
