Home » Audio » Pro Sound » Over Dwell the reverb surf pan
Over Dwell the reverb surf pan [message #27025] Sat, 30 April 2005 00:55 Go to next message
walters is currently offline  walters
For the old fender surf Reverb Tank
1.) How do i get more dwell i want to over dwell the circuit how do i do this?
what modifications do i need to do for this?
2.) I need to make more current to drive the transducer or reverb pan more?
3.) More current to the reverb drive coil? how do i do this?
4.) Do i need a Bigger driver Coil?
5.) How to drive the springs harder?
6.) The Dwell increases the duration of the Decay time?
Re: Over Dwell the reverb surf pan [message #27030 is a reply to message #27025] Tue, 03 May 2005 11:48 Go to previous messageGo to next message
I never had the unit, and can`t help more then to refer you to the book "A desktop reference of hip vintage guitar amp" by Gerald Weber, there`s one little chapter in it "Juice up that 6G15 Fender reverb", pages 150-156. Maybe you can find it somewhere? In short, author suggests to try some "tricks", for example, changing the 12AT7 tube to 12AX7, reccomends RCA 6K6GT tube, mechanical inspection/fixing of the spring tank, and some mods...
Re: Over Dwell the reverb surf pan [message #27032 is a reply to message #27030] Tue, 03 May 2005 12:17 Go to previous messageGo to next message
Should i try hooking up 2 driver circuits to
drive the reverb pan harder more dwell more voltage and current from 2 driver circuits?
Re: Over Dwell the reverb surf pan [message #27035 is a reply to message #27032] Tue, 03 May 2005 12:42 Go to previous message
That`s just me, but I`d never ever mod a vintage gear to perform something that "stock" unit can`t. Fixing and changing of some bad components is a another story.
Previous Topic: SWR California Blonde distortion.
Next Topic: Folded horns - W verses equiangular spiral
Current Time: Wed Oct 21 17:03:15 CDT 2026
