Home » Audio » Pro Sound » 5e3 on the cheap
5e3 on the cheap [message #26993] Thu, 24 February 2005 20:35 Go to next message
David Hutchens is currently offline  David Hutchens
I just rewired an old Bogen 20 watt pa amp with a Tweed Deluxe 5e3 circuit. The power transformer is a little hot (about
430vac with no load) and has no 5vac winding so I'm using the original 6ax5 rectifier tube. The amp sounds pretty good,
a little better than my silver face Champ. My B+ is about 457vdc and the circuit is drawing about 100ma off the
rectifier tube at idle. I'm a little concerned about the high b+ and tube life. Do I need to change the 6v6 cathode bias
resistor value or try to drop the b+ voltage or should I get a new transformer with lower output and a 5vac winding for
a 5y3. I have new tube sockets a blank chassis and a 5e3 eyelet board and want to make a loose copy of the Tweed Deluxe.
If I can use the Bogen transformers I think I can get out between $100 and $150 including speaker and homemade cabinet.
Any suggestions, ideas or observations are appreciated.
David
Re: 5e3 on the cheap [message #27009 is a reply to message #26993] Thu, 24 March 2005 20:33 Go to previous messageGo to next message
tubenit is currently offline  tubenit
I have built a Bogen CHA-20 into a guitar amp using a schematic with my own design. I added 2 12AX7 tubes to add reverb and vibrato. I have drawn the schematic for the amp. The reviews of the amp are on Harmony Central amp data base as I have tried 3 different schematic designs. I would be happy to email a schematic attachment if you wish to see what I have done. I tried using a higher cathode resistor on the power tubes and the current (which is "self biasing") essentially stayed the same. I went from the original measured 328 ohms to 430 ohms with virtually no change. I contacted a friend who is off the chart knowledgeable about amp building and he suggested leaving the original resistor in. I also added a "tweed" switch to break the grounds on the tone stack and a pentode/triode switch to lower power. My friend plays a 5E3 deluxe and agreed the sound of his and mine is similar except that mine has the added reverb and vibrato. tubenit
Re: 5e3 on the cheap [message #27010 is a reply to message #26993] Fri, 25 March 2005 17:15 Go to previous message
David,
I emailed the schematic and a couple of pics of the amp.Can you confirm if you got them, please. If it did not come thru I will try again and send schematic and pics separately.
Thanks,
Tubenit
Previous Topic: intermittent hiss in marshall jcm 800
Next Topic: guitar amp functioning
Current Time: Wed Oct 21 17:04:21 CDT 2026
