Home » Audio » General » Bunch of Cool Stuff
Bunch of Cool Stuff [message #26554] Wed, 09 August 2006 09:34 Go to next message
Leland Crooks is currently offline  Leland Crooks
Here's what fell into my lap:
Heathkit WAP2 PreAmp
Pilotone AA920 Amplifier
Sherwood S3002 Tuner
Eico HFT90 Amp/Tuner
Sherwood S4400 Integrated Amp
ElectroVoice EV1159 Tuner
Bogen DB230 Integrated Amp.
Anything I should do before plugging these in? They all appear to be in fine condition. I don't want to lose tubes accidentally. Most of my experience is solid state. And what's worth refurbing?
Re: Bunch of Cool Stuff [message #26555 is a reply to message #26554] Wed, 09 August 2006 11:38 Go to previous messageGo to next message
The Pilotone amp is a rare piece and sounds gorgeous. The Eico Tuner and Sherwood tuner a great units; I use a Sherwood as my tuner.
I am sure people will have opinions on the value but all of that stuff is worthwhile; especially the Pilot.
Re: Bunch of Cool Stuff [message #26556 is a reply to message #26554] Wed, 09 August 2006 12:00 Go to previous messageGo to next message
Wow! Great catch!
I don't think you'll damage tubes, they're pretty rugged. If they're not spent already, I don't think you'll hurt them with a power-on surge or anything. The filament voltage is usually set by a transformer secondary.
The components I find bad most often are capacitors. Many times the tubes are in great shape. A tube doesn't go bad in storage like a capacitor does. So check the capacitors, especially electrolytics.
Re: Bunch of Cool Stuff [message #26557 is a reply to message #26555] Wed, 09 August 2006 12:01 Go to previous messageGo to next message
Thanks MB. I'm not really looking for value, just what I should take the time and expense to refurb. I just want to listen to it. I might sell some of it, but I doubt it.
Re: Bunch of Cool Stuff [message #26558 is a reply to message #26556] Wed, 09 August 2006 12:17 Go to previous messageGo to next message
I need to apply a load to amplifiers before powering up, do I not? Don't tube amps have to have a load on the output?
Re: Bunch of Cool Stuff [message #26559 is a reply to message #26557] Wed, 09 August 2006 16:28 Go to previous messageGo to next message
I just want to ask' the Pilotone; that model no. is that the 902 by chance? You marked it as a 920; I'm not sure there is a 920.
Re: Bunch of Cool Stuff [message #26560 is a reply to message #26554] Thu, 10 August 2006 07:38 Go to previous messageGo to next message
MWG is currently offline  MWG
Hi Leland, I'd bring it up on a variac if it hasn't been run for a long time. Here is a URL for the Poor Mans Variac if interested. It's explained in post number three.
Re: Bunch of Cool Stuff [message #26561 is a reply to message #26558] Thu, 10 August 2006 11:07 Go to previous messageGo to next message
Yes, it's better to use a load resistor. Tube amps are voltage amps and the output transformer steps down the voltage. So they're sensitive to no-load conditions. But if you don't apply an input signal, there won't be an output signal. It isn't like it will smoke without a load; Just don't crank it unless there's a load.
Re: Bunch of Cool Stuff [message #26562 is a reply to message #26560] Thu, 10 August 2006 19:38 Go to previous messageGo to next message
Thanks. I don't have a variac, and had heard that it's a good idea. I'll do that.
Re: Bunch of Cool Stuff [message #26563 is a reply to message #26559] Thu, 10 August 2006 19:39 Go to previous messageGo to previous message
Been busy all day. I'll check it tomorrow and post.
Previous Topic: P.T.Barnum Was Right
Next Topic: Mannerly Behaviour
Current Time: Wed Nov 04 21:12:57 CST 2026
