Home » Audio » General » Lenco 35
Lenco 35 [message #26229] Mon, 20 December 2004 04:44 Go to next message
James@sideways-on.freeser is currently offline  James@sideways-on.freeser
Excuse my total ignorance! I've just bought a Lenco 35, and the turntable will only turn when the volume knob is switched to zero (rather than -/+). Any ideas what the problem could be?
Re: Lenco 35 [message #26230 is a reply to message #26229] Mon, 20 December 2004 07:06 Go to previous messageGo to next message
The unit is probably reverse wired. Has someone worked on it in the past?
Re: Lenco 35 [message #26231 is a reply to message #26230] Mon, 20 December 2004 08:14 Go to previous messageGo to next message
Well, it's all set in a home-made wooden base, so I assume whoever owned it before worked on the whole thing. Excusing the ignorance again, what does 'reverse wired' mean, and could I easily make it normal again?
Re: Lenco 35 [message #26234 is a reply to message #26231] Mon, 20 December 2004 15:01 Go to previous messageGo to next message
Wait a minute; excuse my ignorance, I read through your post so quickly that what you said escaped me. You claim that you turned the volume nob to zero? I assumed you said the start control to zero. What exactly does the volume nob control? Is this a console set? Thank you J.R.
Re: Lenco 35 [message #26235 is a reply to message #26234] Mon, 20 December 2004 15:32 Go to previous message
Thanks for your replies, JR. I had a look at the wiring and discovered a loose one dangling by the volume control - so should just be a matter of attaching that - pristine condition otherwise and a beautiful machine.
Jim
Previous Topic: Lafayette SK 215 wx 15 inch speakers HELP HELP!!!
Next Topic: Group Build Forum
Current Time: Thu Nov 05 02:56:00 CST 2026
