Home » Audio » General » Re: Lenco Turntable
Re: Lenco Turntable [message #26158 is a reply to message #26157] Sun, 29 August 2004 04:24 Go to next message
Draco is currently offline  Draco
Did you connect to a phono stage input? Are you connecting MM or MC?
You must know be sure these things are done so check them to be sure.
Re: Lenco Turntable [message #26159 is a reply to message #26158] Sun, 29 August 2004 12:24 Go to previous messageGo to next message
José is currently offline  José
Many thanks.
Yes I connect to a phono stage input in my amplifier ( the same input I used with the other turntable- now out of service). The plugs are RCA. My trouble is I cannot get the phonocartridge's alignement properly, as the headshell included in the Lenco brings a cartridge and needle G 800E and I'm trying to use a Shure. Do you know if it is necesary to change the headshell.
Please, what do you mean with MM or MC?
Many thanks from Spain
José.
Re: Lenco Turntable [message #26160 is a reply to message #26159] Mon, 30 August 2004 03:30 Go to previous message
MM is moving magnet and MC is moving coil. MM is more common and if you hook up a MC cartridge to a MM input it will sound funny, like you said. Some have a switch to set which one you want.
Previous Topic: Wireless systems
Next Topic: Deja Vu all over again
Current Time: Thu Nov 05 05:57:45 CST 2026
