Home » Audio » Radio » Montgomery Ward Airline 14BR-736 radio
Montgomery Ward Airline 14BR-736 radio [message #26033] Fri, 15 August 2008 00:35 Go to next message
Dave Everett is currently offline  Dave Everett
I found this radio at a garage sale just today (8/14/08) and I was wondering what year this was made and if there are replacement parts available. According to another website that I visited, this is an Airline 14BR-736 model radio made by Montgomery Wards. Can someone help me find info on this radio?
Re: Montgomery Ward Airline 14BR-736 radio [message #26034 is a reply to message #26033] Fri, 15 August 2008 11:13 Go to previous messageGo to next message
That's excellent. I have a few Airline models and I've found information is scarce to none. The reason is Montomery Ward bought radio chassis from OEM's like RCA and rebranded them. So to find schematics takes a manual process of looking through several to find a chassis that matches tube sets and physical orientation.
Re: Montgomery Ward Airline 14BR-736 radio [message #26035 is a reply to message #26034] Sat, 16 August 2008 09:55 Go to previous messageGo to next message
Wayne,
Thanks for responding. The radio that i have needs some internal work and the plastic yellowish front dial cover needs replaced. Where could I get that particular part? Also, what year (era) was this brand made?
Re: Montgomery Ward Airline 14BR-736 radio [message #26036 is a reply to message #26035] Mon, 18 August 2008 12:30 Go to previous messageGo to next message
You won't find a new replacement dial cover. You might be able to find a parts mule on eBay but I doubt it. If it's just yellowed, I would probably be happy as long as you can still see through it. Just a natural part of aging.
As for dating, you can get an idea from the tube complement. What tubes does it use?
Does the radio work?
Re: Montgomery Ward Airline 14BR-736 radio [message #26037 is a reply to message #26036] Tue, 19 August 2008 23:45 Go to previous messageGo to next message
Yes the radio works. I had to replace the actual power cord and do some soldering. As far as the tubes, it has the original Montgomery Ward Airline tubes in it. See, this radio sat in a vacant house for many many years. The lady that owned it died and no-one ever did anything with it until last weekend.
The face on the radio has yellowed. The radio station here in Rawlins (so far the only one that I can get) works on the radio, but the radio has a hum of sorts. Also, maybe you can tell me, there is a yellow (woven insulated) wire that goes from each side of the radio and across the top (inside the component area) and I'm thinking that it may be the antenna, right? Also one good feature, the dial does still light up. I will send some pics of the radio to you via your e-mail.
Re: Montgomery Ward Airline 14BR-736 radio [message #26038 is a reply to message #26037] Wed, 20 August 2008 12:05 Go to previous messageGo to next message
The hum is most likely a result of the power supply capacitors weakening. I would replace them. They're usually around 20uF, so you can swap them with new polypropylene capacitors. That will solve the hum and that kind of capacitor will last a long, long time.
Re: Montgomery Ward Airline 14BR-736 radio [message #26039 is a reply to message #26033] Tue, 30 September 2008 02:02 Go to previous messageGo to next message
Try this site for replacement parts:
Re: Montgomery Ward Airline 14BR-736 radio [message #26040 is a reply to message #26039] Wed, 01 October 2008 00:08 Go to previous message
Thanks, I will give it a try...
Previous Topic: BOSTON VR3 COMPARED to AXIOM M60v2
Next Topic: Airline 62-308
Current Time: Sun Oct 18 19:35:50 CDT 2026
