Home » Audio » Radio » IF Transformer Woes
IF Transformer Woes [message #25701] Fri, 27 May 2005 01:43 Go to next message
I recently received a Dynaco FM-3 in for repairs that wasn't functioning at all. I found a few broken ferrite slugs in the IF transformers. After some troubleshooting, I found that one IF coil was REALLY messed up. There was no AC continuity through it and no capacitance or inductance that could be measured. I disassembled it to find the coil former had rotated in the base when someone had previously attempted to turn the stuck slugs, and the coils were partially unwound and the magnet wire broken at the connections to the base capacitors.
I have access to a small lathe to turn another identical coil former, and can simply wind new coils on it. But, I still need the 1/4"-28 ferrite slugs. Does anyone know of a source for 1/4"-28 slugs, or replacement IF transformers for the tuner for that matter? I've found #10-32 slugs, but not 1/4"-28.
Thermionic
Tuner repair [message #25702 is a reply to message #25701] Mon, 30 May 2005 15:32 Go to previous messageGo to next message
I have a MD FT-101 that is in need of some TLC. Please email me if you think you can help......Colin (colinhester (at) yahoo (dot) com)
Re: IF Transformer Woes [message #25795 is a reply to message #25701] Wed, 01 March 2006 10:58 Go to previous message
W. Gallagher is currently offline  W. Gallagher
I just read your post and have the same problem - I need to locate 1/4" -28 ferrite slugs for a Dynaco FM-3 (in my case the T-5 discriminator transformer). Did you find a source?
Previous Topic: RCA 7-fh-5
Next Topic: 1946, 1947 RCA Model 65x1
Current Time: Sun Nov 22 15:20:52 CST 2026
