Hi Mark,
Just use wood glue; A white glue will work just fine. Cut the cloth large enough that it can be glued well within the open area so none of the glue wicks into the visible fibers.
I've had good luck with 3M Photo Mount spray adhesive. It's primary use is for mounting artwork. It is tacky and it doesn't wick. I looks wet when it sprays on, but then disappears.
