Home » Audio » Measurement » Using in room tests?
Using in room tests? [message #25199] Thu, 21 April 2005 10:54 Go to next message
adavis464 is currently offline  adavis464
Calibrated the test system but before I do anything is in room testing a good idea.Keep in mind I'm just getting started and I,m not completely a pro at using it but that will improve over time.I,m going to start frequency response in room one channel to start.regards Tim
Re: Using in room tests? [message #25200 is a reply to message #25199] Thu, 21 April 2005 16:20 Go to previous messageGo to next message
In room testing measures the room, anechoic (chamber or outdoors) measures the equipment. If you're interested in a baseline test for equipment comparisons, anechoic is all that makes sense. But if you're interested in setting up your equipment in a specific room, you'll probably want to tailor for that room, and so you'll measure in that room. You'll get diffrent measurements at different places inside the room, so you'll find some good spots and some bad. Depending on how important coverage is to you, you might try to setup for good response over a large area, or you might just set it for best sound in a specific listening spot.
Re: Using in room tests? [message #25201 is a reply to message #25199] Sun, 08 May 2005 04:24 Go to previous messageGo to next message
yehuda is currently offline  yehuda
Hi,
If you are measuring frequency using the MLS then you can measure it in room.
Yehuda.
Re: Using in room tests? [message #25202 is a reply to message #25201] Sun, 08 May 2005 14:59 Go to previous message
If you're concerned with response above the gated frequency, then pseudo-anechoic via gating will suffice. But below the gated frequency, you're getting reflections and room resonances just like with an ungated measurement.
Previous Topic: measuring ability for amatuers
Next Topic: How Do You Use Speaker Workshop?
Current Time: Sat Nov 07 16:22:06 CST 2026
