Home » Audio » Speaker » internalhook up wire
internalhook up wire [message #23358] Thu, 11 January 2007 20:42 Go to next message
Tom R. is currently offline  Tom R.
I am close to mounting the woofer drivers, and wiring them together in my line array.
Does the quality of internal hook up wire between drivers matter?
Doing a rough calculation, I need 70 ft of cable inside the array. Does anyone have an opinion on decent internal hook up wire? I have $50 to $75 USD for this step in the project. Should I get decent cable, or save the money and buy cheep wire?
Tom R
Re: internalhook up wire [message #23359 is a reply to message #23358] Fri, 12 January 2007 00:28 Go to previous messageGo to next message
jeffreybehr is currently offline  jeffreybehr
Tom, you posted this question 2-1/2 hours ago; are you THAT confused?
Re: internalhook up wire [message #23361 is a reply to message #23358] Fri, 12 January 2007 11:02 Go to previous message
Anonymous
Ordinary stranded speaker wire is fine. I would use 18 gauge minimum,
but prefer 16 gauge. You can use bigger wire than that but make sure
it's flexible to make the install easy and as long as it doesn't cost
alot.
Previous Topic: Hook up wire?
Next Topic: O.B. line array on Audio Circle
Current Time: Mon Nov 16 06:49:46 CST 2026
