Home » Audio » Speaker » Woofer array questions
Woofer array questions [message #23314] Mon, 13 November 2006 10:15
Gene K is currently offline  Gene K
I'm thinking of putting in a woofer array, but the parameters that you have to use for mids and tweeters seems a little vague when you decide to put them together for a woofer array.
Jim has made it clear in other posts that woofer arrays must consist of 10 or 12 inch woofers.
Now....
Using the c-to-c rating of the woofer and assuming a crossover of 250hz, the distance between the woofers only needs to be 54 inches, which is 4.5 feet. This would suggest on the combing effects that one really only needs 2 woofers spaced 54 inches apart.
Looking at the nearfield transition data is crazy. A crossover of 250 would suggest an array height of 3-4 meters way larger than my 7.5 foot room height. Page 9-10 talks about this. The suggestion is that the array fills up 70% of 90 inches which is 63 inches.
Two woofers spaced about 4 feet C-to-c would do that, and would raise the sensitivity close to that of the midranges at least in the array, if one is using 92 SPL woofers.
Is this right?
Previous Topic: Best enclosure system for a woofer accompanying?
Next Topic: Piezo Horn drivers
Current Time: Mon Nov 16 06:50:27 CST 2026
