Home » Audio » Speaker » Linus III Arrays Almost Done!
Linus III Arrays Almost Done! [message #23219] Mon, 09 October 2006 09:30 Go to next message
Dan Twomey is currently offline  Dan Twomey
I'm hoping that in another couple weeks my Linus III arrays will be done. This is a kit from Rick and as you can see in the pics I decided to build my own cabinets in my little woodworking shop in my garage.
As a twist of my own I decided that I liked the look of a cabinet with greater depth than width so I designed my cabinets to be approximately 21" deep by 13" wide. Here are a couple of construction pics:
http://ca.geocities.com/dantwomey1@rogers.com/images/almostdone1.jpg
http://ca.geocities.com/dantwomey1@rogers.com/images/almostdone2.jpg
Regards,
Dan
Excellent! [message #23220 is a reply to message #23219] Mon, 09 October 2006 14:08 Go to previous messageGo to next message
Beautiful work!
wow [message #23222 is a reply to message #23219] Tue, 10 October 2006 07:23 Go to previous messageGo to next message
lcholke is currently offline  lcholke
The wood looks very well done. -Linc
Re: Linus III Arrays Almost Done! [message #23223 is a reply to message #23219] Tue, 10 October 2006 11:08 Go to previous messageGo to next message
Anonymous
Cool. More pics when yer done.
Re: Linus III Arrays Almost Done! [message #23226 is a reply to message #23223] Tue, 10 October 2006 14:11 Go to previous messageGo to next message
Another thing I'm hoping to do is put granite bases on them. I'm not sure I can get that to work because each speaker is going to weigh in at 200+lbs.
Regards,
Dan
Re: Excellent! [message #23231 is a reply to message #23220] Thu, 12 October 2006 14:29 Go to previous messageGo to next message
Ray Collins is currently offline  Ray Collins
Excellent work!! I also am considering a Line Array from Rick since Jim Griffin's Linus II is no longer a viable project....the Vifa TC14WG49's drivers are no longer available. Why did you chose the Linus III over the RS8? Also, will changing the baffle width affect the performance?
Re: Linus III Arrays Almost Done! [message #23232 is a reply to message #23219] Thu, 12 October 2006 14:30 Go to previous messageGo to next message
Danse is currently offline  Danse
Super job, now can you build another pair for me!
Just kidding
Robert
Re: Excellent! [message #23233 is a reply to message #23231] Sat, 14 October 2006 17:45 Go to previous messageGo to next message
I chose the Linus III kit over the the RS8 kit because at the time the Linus III kit was on sale and fit my budget.
My baffle is 1 inch narrower than the baffle in the plans that I received. Also, my baffle has radiuses on the front baffle edges where the Linus III plans I received didn't. In theory a radiused front baffle is a good thing.
Regards,
Dan
P.S. Line Array Trivia - 108 pilot holes to drill for driver screws. And that's per speaker!
excellent [message #23234 is a reply to message #23233] Sat, 14 October 2006 21:00 Go to previous messageGo to next message
I am coveting!!!!
108 [message #23235 is a reply to message #23233] Sun, 15 October 2006 10:06 Go to previous messageGo to previous message
Driver mounting holes to drill, T-Nuts to install, screws to drive. 108 times. That's dedication! But like all things worth doing, some effort is required. I know it pays off handsomely in the end!
Previous Topic: Let's try this again - A Very Cool Speaker
Next Topic: mini wall mounted array
Current Time: Mon Nov 16 06:36:05 CST 2026
