Home » Audio » Speaker » Re: Question on calculating woofer box volume
Re: Question on calculating woofer box volume [message #23214 is a reply to message #23213] Tue, 03 October 2006 11:16 Go to next message
Anonymous
>>Is this correct?
yes to all.
If you want best SQ, optimize dimensions for a deeper box size,
add fiberglass stuffing.
Re: Question on calculating woofer box volume [message #23217 is a reply to message #23215] Tue, 03 October 2006 15:28 Go to previous message
Anonymous
>>Qtc = 0.707
This rule isn't written in stone. I have midrange drivers optimized
for small boxes but they will sound bad because the box is too small
and there is too much sound chaos inside the chamber. It would be
better to just violate the rule and make a deep box with good fill
to get a cleaner midrange sound.
If this is confusing, then make a test box to see what I mean.
Get some cheap particle board and make a small midrange box,
then make a deeper one with good fill. Listen to the driver
full range or high pass the driver to keep the bass out so you
don't damage the driver. Compare the sound and see what you like.
There is no guarantees that you will prefer the bigger box, but
you should at least explore that option and verify it.
Deep cabinet.
http://www.speakerbuilding.com/content/1044/09_sanded.jpg
Previous Topic: Wake up Maggie
Next Topic: Ported Enclosure for line array
Current Time: Mon Nov 16 06:35:59 CST 2026
