Home » Audio » Speaker » 4.5 " driver 8 per side for a mini array
4.5 " driver 8 per side for a mini array [message #22897] Tue, 03 January 2006 07:49 Go to next message
yong ah nyak is currently offline  yong ah nyak
please guru assist me, do i need to taper them if so how should i group them ?
thanks
Re: 4.5 " driver 8 per side for a mini array [message #22898 is a reply to message #22897] Wed, 04 January 2006 08:21 Go to previous messageGo to next message
With just 8 4.5" drivers per side, I would not worry about tapering.
Re: 4.5 " driver 8 per side for a mini array [message #22902 is a reply to message #22898] Wed, 04 January 2006 11:01 Go to previous messageGo to next message
hi jim,
thanks, what would be the height for the tweeter that you suggest?
cheers
yong
Re: 4.5 " driver 8 per side for a mini array [message #22907 is a reply to message #22902] Thu, 05 January 2006 21:04 Go to previous messageGo to next message
Yong,
If you are thinking of a single tweeter per side, locate it at ear height for best results.
Jim
Re: 4.5 " driver 8 per side for a mini array [message #22950 is a reply to message #22897] Tue, 21 March 2006 07:32 Go to previous messageGo to next message
RAW is currently offline  RAW
HEre is a few we have done.
The SuperSpires uses 4 of the WR125S with our Aurum Cantus long ribbon
along with a center channel
Re: 4.5 " driver 8 per side for a mini array [message #22951 is a reply to message #22950] Tue, 21 March 2006 07:33 Go to previous messageGo to next message
HEre they are finished in Waterfall Sapele
Re: 4.5 " driver 8 per side for a mini array [message #22952 is a reply to message #22951] Tue, 21 March 2006 07:34 Go to previous messageGo to next message
We use the 8 drivers in the Lambda line array as well with 6 ribbons
Re: 4.5 " driver 8 per side for a mini array [message #22953 is a reply to message #22951] Tue, 21 March 2006 07:35 Go to previous messageGo to next message
nOw the SSR center channel
Re: 4.5 " driver 8 per side for a mini array [message #22954 is a reply to message #22897] Tue, 21 March 2006 07:37 Go to previous message
The line we did uses the 8 WR125ST 16ohm drivers and our AC ribbon tweeter this line has a easy load on a amp with a 9ohm load.
Previous Topic: Sub placement
Next Topic: POsting measurements here & copyright: Help, Wayne
Current Time: Mon Nov 16 06:35:57 CST 2026
