Home » Audio » Speaker » Array with Aurum G1 and Extremis?
Array with Aurum G1 and Extremis? [message #22828] Fri, 30 September 2005 23:56 Go to next message
Niclas Williams is currently offline  Niclas Williams
Hi,
I am intressting to do a line arrays with 10 pices of Adire Extremis 6.8 and 10 pices of aurum cantus G1 (each side).
Do you think this is a god project?
Should i go for closed box or vented box?
(i will also use two subwoofers to this system - velodyne DD-15)
Re: Array with Aurum G1 and Extremis? [message #22829 is a reply to message #22828] Sat, 01 October 2005 10:20 Go to previous messageGo to next message
justinc is currently offline  justinc
I think using the extremis would be a great idea and have also thought about this. Im not sure if the G1 can be crossed as low as it would need to be around 1.8-2khz, you might want to consider the fountek neo or even better yet the fountek pro5i which is around the same price as the ac and probably much better. It has higher sensitivity and can be crossed very low. I would also probably go with a large sealed cabinet using those drivers since you have two subwoofers already.
Re: Array with Aurum G1 and Extremis? [message #22830 is a reply to message #22828] Mon, 03 October 2005 11:51 Go to previous messageGo to next message
Anonymous
Should be a cool project.
Do you mean Good project or God project?
It's a very good project, but I can think of Godlier
designs if your wallet is fatter
Make a scale down test box, rear ported, then plug the hole to make
it a sealed box. Listen to both ported and sealed, what do you
prefer sonically ?
Re: Array with Aurum G1 and Extremis? [message #22831 is a reply to message #22830] Mon, 03 October 2005 12:15 Go to previous message
Thanks! I have order 2 pcs of G1 and 2 pcs of Extremis 6.8 for a test (sealed and ported).
Previous Topic: Gumby MkI finally gets new clothes !!
Next Topic: A little article about a BLH....why go to the trouble.....
Current Time: Mon Nov 16 06:18:24 CST 2026
