Home » Audio » Speaker » Idea for alternative to power tapering
Idea for alternative to power tapering [message #22678] Sat, 25 June 2005 15:07 Go to next message
Abra Cadaver is currently offline  Abra Cadaver
I'm not suggesting that this will work, I'm just tossing it out as an idea. Instead of power tapering, how about making a fabric grill that has more layers of fabric on the outer drivers than the inner ones?
Re: Idea for alternative to power tapering [message #22682 is a reply to message #22678] Mon, 27 June 2005 16:03 Go to previous messageGo to next message
Have you seen the response curves comparing speakers with and without grills?
eric j
one of the first [message #22685 is a reply to message #22678] Mon, 27 June 2005 21:30 Go to previous messageGo to next message
lcholke is currently offline  lcholke
Hi
I saw this done in an old AES paper in the 1-25 audio anthology collection.(1962) It is still a clever idea. They used fiber glass. It must have worked for them to publish and install in a church. Their final unit was usable from 300 to 10khz with eq. The other old way is to rotate the drivers around a pole.
-Linc
Re: Idea for alternative to power tapering [message #22728 is a reply to message #22678] Mon, 18 July 2005 13:54 Go to previous messageGo to next message
As stated, this is not a new idea. Unlike constant power tapering, the absorption tapering is frequency dependent, which is an added degree of freedom to facilitate a better design.
I use a similar principle in my waveguides to improve pattern control - a foam plug - and it works extremely well. It is an idea with a lot of potential, but it can be very difficult to actually design using.
Re: Idea for alternative to power tapering [message #22744 is a reply to message #22728] Fri, 22 July 2005 10:00 Go to previous messageGo to next message
Earl,
Any thoughts on foam selection. Open cell is probably required. What materials and thickness come to mind.
-Thanks
-Linc
Re: Idea for alternative to power tapering [message #22745 is a reply to message #22744] Fri, 22 July 2005 11:11 Go to previous message
Open cell polyurethane foam comes in an extremely wide variety of cell density and is ideal for the application. Only a model or experimentation could determine what sizes and thicknesses would be required - guessing would probably be a waste of time.
Previous Topic: bsc and edge defraction
Next Topic: Fostex FE206 in DBR
Current Time: Mon Nov 16 06:20:22 CST 2026
