Home » Audio » Speaker » Car components for home line array
Car components for home line array [message #22576] Mon, 04 April 2005 03:31 Go to next message
JP Haggar is currently offline  JP Haggar
I get the greates pleasure listening to music in my car , although I have normal pioneer 6x9" 3 way speakers in the back and two 6x4" 2 way in the front the effect is wonderful , I wondered if I use those same 6x9" 3way (with centered mid and treble )put 6 of those units into a line array configuration for home use ??? any comments would be very much appriciated .
Thanks
JP Haggar
Re: Car components for home line array [message #22579 is a reply to message #22576] Mon, 04 April 2005 22:12 Go to previous message
Dave Peterschmidt is currently offline  Dave Peterschmidt
JP,
I don't believe that'd work very well. For one thing, your tweets wouldn't be close enough together, causing some comb filtering effects. Depending on where the crossovers are set, you might also have that problem with the mids. I would think you'd be better off buying speakers designed for home use and creating an array with them rather than trying to shoehorn car speakers into a usage they weren't designed for.
Previous Topic: Altec 515B
Next Topic: Schematics for JanZens?
Current Time: Mon Nov 16 06:02:31 CST 2026
