Home » Audio » Speaker » Experiences with Jordan JX53 or Bandor 50 mm in line array?
Experiences with Jordan JX53 or Bandor 50 mm in line array? [message #22214] Sat, 14 August 2004 11:25 Go to next message
Has anyone any experience with either of these drivers. I thought possibly using them in a TL design with out the need for a tweeter or crossover could be good. Also, the Bandor drivers are available in a 16 ohm version. Any thoughts or direction to existing designs using either of the drivers would be helpful.
Thanks
Norris Wilson
http://www.ejjordan.co.uk/drive_frameset2.htm
http://www.bandor.com/products_frame.htm
Re: Experiences with Jordan JX53 or Bandor 50 mm in line array? [message #22268 is a reply to message #22214] Thu, 02 September 2004 17:42 Go to previous message
7V is currently offline  7V
Norris, I haven't used Jordan drivers for many years. However, I have designed some mini-array speakers using the Bandor 50mm units and can thoroughly recommend them.
I have designed a TL version (see link below) but my latest design uses the 50mms in a sealed enclosure and accompanies them with separate bass speakers.
Bandor do a 16 ohm version, as well as 8 ohm and 4 ohms. I have used the 8 ohms in the past but prefer the 4 ohms these days as the moving mass is lower and high frequencies better.
Steve Margolis
Previous Topic: c-t-c formula and tweeter placement
Next Topic: Line array's
Current Time: Mon Nov 16 05:28:09 CST 2026
