Home » Audio » Speaker » LA HF horns
LA HF horns [message #22172] Mon, 26 July 2004 21:26 Go to next message
DSM is currently offline  DSM
Whats the requirements for a Line array HF horn?
I notice DDS now makes a dual 1" horn.
Not really sure how summation takes place.
If its a very narrow vert coverage, does each fill a zone with no overlap? I just can't comprehend that given the required bandwidth and beaming thats happening in the upper octave(s).
Wish I could afford ribbons.
Much simpler than you may think. [message #22173 is a reply to message #22172] Tue, 27 July 2004 12:55 Go to previous message
What's critical is the distance between the radiating planes of the individual elements, which ideally is kept under a wavelength. This rules out 1" domes that have 2" wide mounting flanges but other options are available. A simple rule of thumb states that if the radiating plane of the array comprises are least 90% of the meaured vertical plane then you're OK. Where horns are concerned the radiating area is the horn mouth, exclusive of the mounting flange.
Previous Topic: Very nice cabinet work for Fostex 168
Next Topic: Corner Placement: In or Out?
Current Time: Mon Nov 16 05:28:40 CST 2026
