Home » Audio » Speaker » why are most array line and not cluster
why are most array line and not cluster [message #22169] Wed, 21 July 2004 16:30 Go to next message
adavis464 is currently offline  adavis464
what about clusters on an open baffle?
Re: why are most array line and not cluster [message #22170 is a reply to message #22169] Thu, 22 July 2004 05:48 Go to previous message
I assume by cluster you mean that there are drivers going both vertically and horizontally. Placement of drivers on the horizontal plane reduces horizontal dispersion and leads to comb filtered response. The overall result, to be succinct, sucks. The only time that cluster arraying works well is when the distance across the array is less than 1/2 wavelength; otherwise pathway differentials between the various sources and off-axis listening positions create massive dips and peaks in response.
The only time a cluster array is of benefit is when it is engineered to intentionally deliver a very narrow dispersion on both the horizontal and vertical planes, which can be useful in voice only industrial applications but isn't worth much for music.
Previous Topic: altec - old vs new
Next Topic: This looks like it will rock
Current Time: Mon Nov 16 05:27:43 CST 2026
