Home » Audio » Speaker » Ciare HX-201 10" wideband?
Ciare HX-201 10" wideband? [message #21404] Thu, 29 December 2005 08:32 Go to next message
Has anyone used or heard the Ciare HX-201 10" wideband driver?
It looks like a good candidate for a crossoverless mid-bass driver for a 3-way speaker system.
It would be nice to find a good wideband driver that does not use a whizzer cone and can extend to around 8kHz. At least without shouting due to peaks around this frequency, like most of the larger wideband drivers do that do not use a whizzer cone.
Any input will be appreciated.
Norris Wilson
Re: Ciare HX-201 10" wideband? [message #21411 is a reply to message #21404] Sun, 01 January 2006 22:33 Go to previous messageGo to next message
Looks good Norris, but may be a bit bright soundng, based on looking at the frequency curve.
Re: Ciare HX-201 10" wideband? [message #21417 is a reply to message #21404] Tue, 10 January 2006 13:31 Go to previous message
robertG is currently offline  robertG
If you plan to use it in a three way system, why bother with a 10 inch driver?
I mean, you could get away with a much nicer 5 or 6 in. driver with a smoother roll-off, such as Fostex extended range woofers.
Previous Topic: Cheap and easy phase plug
Next Topic: Updated the crossovers on my K-orns to spec
Current Time: Mon Nov 16 06:17:59 CST 2026
