Home » Audio » Speaker » EPI /TL / EQ compensation
EPI /TL / EQ compensation [message #21342] Wed, 09 November 2005 01:45 Go to next message
Rowdy01 is currently offline  Rowdy01
I have a pair of EPI micro-towers, they have 2 full range speakers in a dipole fig. There is no crossover and the speaker box is a TL config. They sound good for what they are but they lack in the bottom end. The 2 drivers are 8 ohms and are wired in parallel. Is there an EQ circuit (zobel) that I could add to these speakers that would help them in better sound ?
Re: EPI /TL / EQ compensation [message #21343 is a reply to message #21342] Thu, 10 November 2005 09:46 Go to previous messageGo to next message
Try a 3 ohm resistor in parallel with a choke, similar to Fostex drivers on Martin King's website. TEll us what you think.
-akhilesh
Re: EPI /TL / EQ compensation [message #21344 is a reply to message #21343] Thu, 10 November 2005 09:48 Go to previous messageGo to next message
Try a 3 MH choke with the 3 ohm resistor.
thanks
-akhilesh
Re: EPI /TL / EQ compensation [message #21419 is a reply to message #21344] Wed, 25 January 2006 15:22 Go to previous messageGo to next message
I ended up using a 3.mh coil and a resistor value of 4.2 ohms (2 in parallel) Thanks for the advice. Ron
Re: EPI /TL / EQ compensation [message #21421 is a reply to message #21419] Wed, 25 January 2006 20:56 Go to previous message
Glad it worked out, Ron.
Share your listening experience in a new thread...that will help other starting out.
-akhilesh
Previous Topic: Line array madness
Next Topic: Porting of Line Array
Current Time: Mon Nov 16 06:18:40 CST 2026
