Home » Audio » Speaker » Somebody got plans for sub horn(s)?
Somebody got plans for sub horn(s)? [message #20643] Sun, 06 February 2005 07:32 Go to next message
Kane is currently offline  Kane
I´m looking for drawings for a sub horn design. Must be able to fit inside a livingroom without throwing out the sofa(or my wife throwing out me!!)
Tanks!
Re: Somebody got plans for sub horn(s)? [message #20644 is a reply to message #20643] Sun, 06 February 2005 07:55 Go to previous messageGo to next message
Check Fitz's forum:
Re: Somebody got plans for sub horn(s)? [message #20649 is a reply to message #20643] Tue, 08 February 2005 15:39 Go to previous messageGo to next message
Mariogert is currently offline  Mariogert
Try: http://homepage3.nifty.com/spida/pag9-01-16.htm a Japanese freak site on the subject that I found today.
Re: Somebody got plans for sub horn(s)? [message #20655 is a reply to message #20644] Thu, 10 February 2005 20:53 Go to previous messageGo to next message
Hi All,
I just got the download for Bill's "Tuba 18" subwoofer. Not too difficult to build and it should work great for music and home theater.
Steve
Re: Somebody got plans for sub horn(s)? [message #20656 is a reply to message #20655] Thu, 10 February 2005 22:59 Go to previous messageGo to next message
lon is currently offline  lon
Depends on the tools I suppose, but I'd appreciate any writeup
with photos you may care to share in your progress on the tuba 18.
There's an article on it in _audioXpress_ 2 months ago as well.
Look at the response curve first, [message #20657 is a reply to message #20656] Fri, 11 February 2005 00:16 Go to previous messageGo to next message
Gazmo is currently offline  Gazmo
Bill Fitzmaurice “tuba” horns are meant for guitar and bass. The response has 15dB peaks and valleys so I don't think it is for critical listening or even home theater. IMO, YMMV, yada, yada, yada.
Re: Look at the response curve first, [message #20658 is a reply to message #20657] Fri, 11 February 2005 07:04 Go to previous messageGo to next message
zobsky is currently offline  zobsky
Original Message:
... have you listened to a tuba 18 or an auto tuba ?
i built one and have listened to it enough to confidently say that i disagree wholeheartedly with your post, .. YMMV
cheers
Re: Look at the response curve first, [message #20660 is a reply to message #20658] Fri, 11 February 2005 11:01 Go to previous message
I am glad you are happy with them. I wouldn't try to talk you out of that. Bass players like them too. However, I think most here would want a more refined sub, that's all. The response curve is very peaky. It is what it is.
Previous Topic: Horns vs. Cones
Next Topic: hold a listening meet
Current Time: Mon Nov 16 05:43:40 CST 2026
