Home » Audio » Speaker » Backhorns
Backhorns [message #19989] Fri, 07 May 2004 09:08 Go to next message
Bradford is currently offline  Bradford
Are backhorns actually horns or are they more of a tapered transmission line? The reason I ask is that I can't figure out why some say backhorns are more efficient and others say no. Seems like the backhorn would add bass but nothing beyond, so it is like a tapered pipe. Your thoughts?
Re: Backhorns [message #19990 is a reply to message #19989] Fri, 07 May 2004 09:37 Go to previous messageGo to next message
Well a back horn works on several principals. The first being the changing of pressure to amplitude ,which a TL dosent do.A backhorn is , in essence, a 1/2 wave resonator that has to be 1/4 wave minimum length.The higher efficency comes back from the flare rate , a very tight flare, ex. hyperbolic, can have up to a 70% conversion from electrical energy to mechanical. A conical will be quite a bit lower.However the tighter flare will increase distortion.The main factor in a horn is its ability to cover 3-4 octaves in gain, where a BR would cover around 1/2 octave, as well as the perception of "speed".You add to this the TL action and you get superior (in some designs) results.
Its all in what you really want.I switched from TLs and TQWT (kinda TL,BR,horn action)simply due to the extreem dynamics and reality of the sound.
ron
Re: Backhorns [message #19991 is a reply to message #19990] Fri, 07 May 2004 17:04 Go to previous messageGo to next message
Sounds like a good idea, but regarding efficiency, there is no difference between backhorn, pipe, tapered pipe and plain boxes, right? I understand the differences are in bass below 100 hz.
Re: Backhorns [message #19992 is a reply to message #19991] Fri, 07 May 2004 19:39 Go to previous message
Not really, a BR TL,sealed enclosure is around 5% or < efficent.In my horn designs i go for around a 300 Hz roll off from the horn mouth and the baffle simulates a 300 hz OB so the baffle picks it up at that point.I also try to design a flared mouth that tapers into the baffle so there is less mechanical crossover.Its best to even have the driver in the mouth, but i havent found a realistic way to accomplish that .......yet!!!!LOL
ron
Previous Topic: LC tuning instead of ports
Next Topic: Isophon Speakers/Drivers
Current Time: Mon Nov 16 05:26:42 CST 2026
