Home » Audio » Speaker » Vintage 15" woofer recommendation for OB midbass array?
Vintage 15" woofer recommendation for OB midbass array? [message #19374] Tue, 06 November 2007 17:02 Go to next message
I have been thinking about many of the efforts that are being made in the OB design arena recently.
In the Beyond the Ariel's post over at DIY audio loudspeaker forum. There have been many enlightening aspects of OB speakers revealed. One major issue in order to obtain high SPL output ability. One has to increase radiating area as the frequency goes lower.
In the name of expense, I thought four vintage 15" mid to higher Qts pro woofers could be desirable, say a Qts of.5 to .9. I think two 15" woofers per channel stacked vertically for the midbass region should be sufficient to obtain a real world 100db in my listening room.. My Philips AD5200M 12" fullrange drivers could work for the midrange, and possibly a vintage cheap compression driver for the tweeter.
I would bi-amp this speaker, actively limiting the bottom frequencies of the midbass drivers, using a passive filter to roll of the top. Also, limiting the midrange bottom close to where the midbass is rolled off. This could be done by lowering the coupling capcitor value in the amplifier, and passiively rolling off the top of the midrange with a coil. The tweeter would be passively crossed in.
Of course this system would require active subwoofers, that I have, for the sub 50Hz frequencies.
I have been listening to a pair of Philips AD5200M 12" fullrange drivers on a large baffle for a few years now. "Thanks spkrman57" But, there are many short comings of this approach using this particular woofer with a whizzer cone. The main short comings are mainly due to the whizzer cone distortion at high SPL's, beaming, and the effects of running a 12" cone above 2kHz, which is poor high frequencie reproduction.
I would love a vintage 15" woofer recommendation for the OB midbass driver that has a mid Qts around .5 to .9 range. A frequency range for this OB midbass section could be optimum at 50Hz to 200Hz.
I have chosen vintage woofers as the most cost effective, to include resale if this all turns into a pile of waisted efforts.
Any input about my hypothetical OB speaker would be greatly appreciated? Any other recommendations for midrange and tweeters would be helpful as well.
Thanks
Norris Wilson
Re: Vintage 15" woofer recommendation for OB midbass array? [message #19375 is a reply to message #19374] Tue, 06 November 2007 20:25 Go to previous messageGo to next message
You might give the Eminence Alpha 12 and Alpha 15 a try. They're high Q woofers that might work for you.
Re: Vintage 15" woofer recommendation for OB midbass array? [message #19376 is a reply to message #19375] Wed, 07 November 2007 15:16 Go to previous messageGo to next message
Thanks Wayne for the recommendation.
Norris
Re: Vintage 15" woofer recommendation for OB midbass array? [message #19377 is a reply to message #19376] Thu, 08 November 2007 09:21 Go to previous messageGo to next message
The Alpha's aren't hugely expensive either, so building an array will be something you can do without breaking the bank.
Re: Vintage 15" woofer recommendation for OB midbass array? [message #19378 is a reply to message #19374] Fri, 09 November 2007 09:44 Go to previous messageGo to next message
Floyd Andrews is currently offline  Floyd Andrews
These are 12" woofers, not 15" as you requested, but the Selenium 12PW3-SLF woofers are on sale at Parts Express for $40 each and have a Qts of .69. I don't have any experience with OB, so I can't comment on their suitability, but I do have some Selenium 15" woofers in a ported box and they are very nice speakers.
Re: Vintage 15" woofer recommendation for OB midbass array? [message #19381 is a reply to message #19377] Sat, 17 November 2007 04:53 Go to previous message
DanTheMan is currently offline  DanTheMan
A lot of peope are using the Alpha 15s with much reported success. It's specs are not too far off from the Silver Iris so it shopuld work well for OB.
Previous Topic: Pro line arrays
Next Topic: Open back array
Current Time: Sun Oct 25 11:56:04 CDT 2026
