Home » Audio » Speaker » Bandpass for JBL 2240H
Bandpass for JBL 2240H [message #18818] Fri, 11 August 2006 18:02 Go to next message
Rapid is currently offline  Rapid
Hello!
I'm looking at a 4th order bandpass sub with a JBL 2240H, but a simple bassreflex tuned to 25Hz seems to give higher maximum SPL. Simulations were done in WinISD. Any suggestions on a design? Low frequency limit should be about 20-25Hz.
I tried rear chamber=187 l, front chamber=41 l, tuning freq=56Hz.
Thanks!
Re: Bandpass for JBL 2240H [message #18819 is a reply to message #18818] Sun, 13 August 2006 21:04 Go to previous messageGo to next message
GM is currently offline  GM
Greets!
Forget BP unless tuned high, and to get to 20 Hz with any authority will require a huge cab, so how big can you tolerate and what's the desired XO point?
GM
Bassreflex suggestion [message #18820 is a reply to message #18819] Mon, 14 August 2006 11:46 Go to previous messageGo to next message
Hi GM!
ok. I've done some simulations as you can see in the picture. I think 200litre is the maximum I can tolerate since I live in an apartment now. Crossover frequency is about 80 Hz. To me, it seems like there's no point going larger than 200litres. I only gain about 3 dB in maxspl 20-25Hz by going to 310litres and the loss in magnitude for the smaller box is not a problem since I'll use an equalizer for room compensation. I'll probably have +-10dB peaks in the bass anyway I've got two 2240s so maxspl should be atleast 116 dB, right?
Does it seem reasonable?
Re: Bassreflex suggestion [message #18821 is a reply to message #18820] Mon, 14 August 2006 21:44 Go to previous message
Greets!
Bummer, I was hoping you'd try a big folded TL that sims 100 dB/W/m half space from 30-70 Hz. You could use it as a platform to mount your mains/whatever. Two would get a bit unwieldy though unless stacked on top of each other against the wall.
In theory, you'll get ~112.78 dB/600 W/m/20 Hz/half space peaks with one, so summing two = ~115.79 dB in 'stereo', but ignoring room gain it will be less due to thermal power compression.
GM
Previous Topic: Needle Array Plans?
Next Topic: Planar speakers
Current Time: Mon Nov 16 06:37:09 CST 2026
