Home » Audio » Speaker » Port Calculation
Port Calculation [message #18258] Fri, 11 November 2005 07:49 Go to next message
Need some confirmation here... if a design calls for two ports that are 4" dia, x 6.5" long, I figure the volume of each to be 81.7", or a total volume of 163.4". Now if I wanted to use a rectangular port instead it would need to have the same volume, right? So if I wanted to make it 18" wide and 1" tall, it would need to be about 9" deep, right?
Thanks!
Re: Port Calculation [message #18260 is a reply to message #18258] Fri, 11 November 2005 08:44 Go to previous message
Make the area equal. Some of the T/S box analysis programs will calculate multiple ports, so they might be helpful.
Previous Topic: Say GM what do you think about Altec 288 drivers?
Next Topic: 80-100hz corner horn??
Current Time: Mon Nov 16 06:19:45 CST 2026
