Home » Audio » Speaker » sensitivity: conversion of units
sensitivity: conversion of units [message #17952] Wed, 08 June 2005 11:32 Go to next message
Floyd Andrews is currently offline  Floyd Andrews
Can anyone tell me how to convert the sensitivity of a speaker that is expressed as a percentage to db/watt or db/2.83volts?
Re: sensitivity: conversion of units [message #17953 is a reply to message #17952] Wed, 08 June 2005 11:49 Go to previous messageGo to next message
I can tell you how, but I don't have time to work out the details.
The % times the input watts tells you the watts radiated as sound. At one meter these watts would cover an area of 4/3 PI R^3. The radiated watts are "proportional to" Pressure^2/unit area, with the area of the spher as noted. So multiply the radiated watts by the area of a sphear at 1 meter and you have pressure^2 (within some constants). From this you can get the dB with a log and some more constants. You can look up the constants.
Re: sensitivity: conversion of units [message #17954 is a reply to message #17952] Wed, 08 June 2005 13:31 Go to previous messageGo to next message
GM is currently offline  GM
Greets!
I've seen various values used for half space pressure, from 112 -112.2 dB/m, though 112 seems to be the most common. FWIW, I calc'd it at 112.018, so rounding it off to 112 and 1 % eff.........
dBv = ~112+10*(log10(0.01)) = ~92 dB/~2.828V/m
Since 1 W = E^2/R = ~2.828^2/8 = 1, then dBa = ~92 dB/W/m for 8 ohm nominal loads.
To convert other nominal resistances (R) to dBa, add 10*log10(R/8) to the dBv, so if the above is a nominal 4 or 16 ohms, then dBa = ~89 or 95 dB/W/m.
GM
Re: sensitivity: conversion of units [message #17956 is a reply to message #17954] Thu, 09 June 2005 14:34 Go to previous messageGo to next message
How did you get the 112 dB? Thats nice to know.
I think that 1/2 space is incorrect since sensitivity is ususally an anechoic measurement which is full space. The correction for speaker impedance is hardly ever used.
Re: sensitivity: conversion of units [message #17960 is a reply to message #17956] Fri, 10 June 2005 08:44 Go to previous messageGo to next message
Greets!
?? 120+(10*LOG10(1/'space')), where 'space' in this case is (2*pi), or half space.
GM
Re: sensitivity: conversion of units [message #17961 is a reply to message #17960] Fri, 10 June 2005 12:48 Go to previous messageGo to next message
Ok
So where does the 120 come from? This seems too simple to me to be correct. Could you fill in the details?
Re: sensitivity: conversion of units [message #17962 is a reply to message #17961] Fri, 10 June 2005 16:32 Go to previous messageGo to next message
Greets!
Fairly simple, or I wouldn't understand it:
Lw = 10*log10(1 Wa/10^-12W) = 120
where:
Lw = sound power level in dB
1 Wa = one acoustic watt
10^-12W = sound power standard reference for the threshold of hearing
GM
Re: sensitivity: conversion of units [message #17964 is a reply to message #17962] Mon, 13 June 2005 11:08 Go to previous messageGo to next message
I guess it is simpler than I though at first, but quite obviuos now.
Thanks
Re: sensitivity: conversion of units [message #17995 is a reply to message #17964] Thu, 23 June 2005 14:46 Go to previous message
Walt is currently offline  Walt
Maximum efficiency is 109db fullspace, which translates to 112db halfspace.
Best regards,
Walt
Previous Topic: Linus Array
Next Topic: Electrostatic Speakers
Current Time: Mon Nov 16 06:02:18 CST 2026
