Home » Audio » Speaker » Do active crossovers......?
Do active crossovers......? [message #17826] Sat, 14 May 2005 07:47 Go to next message
Nubwitz is currently offline  Nubwitz
It would seem that there is a relationship between higher efficiency speaker's dynamic range and the benefits of an active crossover system, and multiple amps.
Could anyone care to comment.
Thank you in advance.
Re: Do active crossovers......? [message #17827 is a reply to message #17826] Sat, 14 May 2005 08:47 Go to previous messageGo to next message
I would say that, in essence, if you are concerned about efficiency then power losses through passive crossovers are best avoided.
Re: Do active crossovers......? [message #17830 is a reply to message #17826] Sat, 14 May 2005 18:16 Go to previous message
The reason to go active is mostly for the amp, not the speakers. There are other things that come into play because of the reactive nature of the loudspeaker load, but the main thing is the bandwidth reduction of each amp. Reduced bandwidth helps keep 'em from clipping. The less you have HF modulated by LF, the more dynamic range you can get from the amp before hitting the power rails.
Previous Topic: Opinion: "The Brick" a folded TQWP for Tangband 871-S
Next Topic: Carver planars
Current Time: Mon Nov 16 06:01:04 CST 2026
