Home » Audio » Speaker » Horn tweeter choice question
Horn tweeter choice question [message #17823] Fri, 13 May 2005 13:06 Go to next message
I need to look at tweeter horns with published frequency/db responses that are pretty flat to 20K.
My price range is really no more than $40 per tweeter. At the moment I am looking at the Eminence APT's with either the 80 degree conical lens or the rectangular horn lens, or the Fostex 100HT.
Does anybody have any experience with these? And does anybody know of any others within my price range, that also have published frequency curves. CD horns are OK. I will have the equalization necessary with the electronic crossover on the Behringer CX3400.
kind regards,
eric j.
Re: Horn tweeter choice question [message #17833 is a reply to message #17823] Sun, 15 May 2005 03:34 Go to previous message
On audioasylum some one discussed APT50s recently use the search engine
Previous Topic: Carver planars
Next Topic: 35 Hz and you
Current Time: Mon Nov 16 06:01:34 CST 2026
