Home » Audio » Speaker » Does anyone have a small format Altec compression driver handy?
Does anyone have a small format Altec compression driver handy? [message #17821] Fri, 13 May 2005 11:49 Go to next message
If you do, I'd appreciate if you could post the C-C measurement of the stud bolts?
Thanks very much for any help.
Charlie
Re: Does anyone have a small format Altec compression driver handy? [message #17822 is a reply to message #17821] Fri, 13 May 2005 12:28 Go to previous messageGo to next message
I get 3" exactly on an 802.
Re:thanks very much! -t [message #17824 is a reply to message #17822] Fri, 13 May 2005 16:31 Go to previous message
-t
Previous Topic: first set of measurments
Next Topic: Array vs Horn
Current Time: Mon Nov 16 06:01:08 CST 2026
