Home » Audio » Speaker » Speaker efficiency?
Speaker efficiency? [message #16858] Sat, 21 August 2004 07:12 Go to next message
Suppose somebody said that their mid-woofer achieved "106dB sensitivity at 80Hz", which someone recently did.
I guess I'd make the assumption that the reference was 1 watt input, rather than gaming the sub-8 ohm impedence vs. 2.83V thing, but you never know.
I read somewhere that 109dB SPL is one equivalent to 1 (acoustic) watt.
If the claim above were true, that would seem indicate a conversion efficiency of over 97%. That seems like a much higher efficiency than I would have thought was possible.
Am I looking at this correctly?
Re: Speaker efficiency? [message #16859 is a reply to message #16858] Sat, 21 August 2004 07:45 Go to previous messageGo to next message
Using the figures you give the efficiency would be 50%. 106dB is down 3dB from 109dB, and 3dB represents a halving/doubling of power. Efficiency = power out/power in, expressed as a percentage.
Re: Speaker efficiency? [message #16863 is a reply to message #16859] Sat, 21 August 2004 11:16 Go to previous messageGo to next message
Damn! What an idiot I can be some times, eh?
Thanks, Bill
Re: Speaker efficiency? [message #16864 is a reply to message #16863] Sat, 21 August 2004 15:28 Go to previous messageGo to next message
jbarlow is currently offline  jbarlow
From what I understand 50% efficiency is nearly impossible, some say fully impossible. A Klipschorn is rated 104db. The T36 rated at 108db and I'd say somewhat exaggerated at that. Either way, 106db is real damn good and can only be achieved by a very efficient bass horn.
Re: Speaker efficiency? [message #16866 is a reply to message #16858] Sat, 21 August 2004 16:00 Go to previous messageGo to next message
Hallowed Sound is currently offline  Hallowed Sound
Efficiency of 100% is measured as 112dB with one watt one meter away radiated as an omnidirectional sphere. If radiated into 1/8 space, it is 121dB/W/M.
Re: Speaker efficiency? [message #16870 is a reply to message #16864] Sun, 22 August 2004 12:21 Go to previous messageGo to next message
Magnus is currently offline  Magnus
Yes, and their radiation pattern do most likely not occupy full space...
/Magnus
Re: Speaker efficiency? [message #16872 is a reply to message #16870] Sun, 22 August 2004 15:23 Go to previous messageGo to next message
Good point. A horn making 108db probably would only be able to do about 100db if it was onmidirectional. Jeff
Re: Speaker efficiency? [message #16873 is a reply to message #16872] Sun, 22 August 2004 15:38 Go to previous message
Keep in mind that the standard for measuring any speaker's SPL is half-space anechoic, so I wouldn't quibble about a horn being quoted at 108dB. I can't think off hand of any speaker being measured in an omnidirectional mode. When it comes to HF horns the radiating plane is often going to be a wavelength through the majority, if not all, of the passband, so the idea of them radiating onmidirectionally doesn't apply in any event.
Previous Topic: Horns / Arrays
Next Topic: Electro Voice EV15L
Current Time: Mon Nov 16 05:27:25 CST 2026
